Inleiding
You can use this guide if you have a cracked back cover for your ZTE Grand X Max Plus and want to replace it.
You can also use this as a guide to open your phone.
Wat je nodig hebt
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
Carefully remove the cover from the phone.
Pics are a little dark. See if you can play with the white balance to correct this.
What if you have no heating element or source
mlp100686 - Antwoord
