Ga door naar hoofdinhoud
ZTE Blade X Max Motherboard Replacement
Wat je nodig hebt
  1. ZTE Blade X Max Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 ZTE Blade X Max Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
  2. ZTE Blade X Max Motherboard Replacement: stap 2, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement: stap 2, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
  3. ZTE Blade X Max Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
  4. ZTE Blade X Max Motherboard Replacement: stap 4, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement: stap 4, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
  5. ZTE Blade X Max Motherboard Replacement: stap 5, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement: stap 5, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
  6. ZTE Blade X Max Motherboard Replacement: stap 6, afbeelding 1 van 2 ZTE Blade X Max Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
  7. ZTE Blade X Max Motherboard Replacement, Midframe: stap 7, afbeelding 1 van 1
    • Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
  8. ZTE Blade X Max Motherboard Replacement: stap 8, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement: stap 8, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
  9. ZTE Blade X Max Motherboard Replacement: stap 9, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement: stap 9, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Use the Jimmy to remove the midframe from the device.
  10. ZTE Blade X Max Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement, Motherboard: stap 10, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement, Motherboard: stap 10, afbeelding 3 van 3
    • Remove the single 1mm Phillips #000 screw from the motherboard.
    • Detach the five flat connectors.
  11. ZTE Blade X Max Motherboard Replacement: stap 11, afbeelding 1 van 2 ZTE Blade X Max Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Use tweezers to remove the protective foam surrounding the headphone jack at the top left of the device.
    • The foam is attached with a thin layer of adhesive which is easy to remove.
  12. ZTE Blade X Max Motherboard Replacement: stap 12, afbeelding 1 van 3 ZTE Blade X Max Motherboard Replacement: stap 12, afbeelding 2 van 3 ZTE Blade X Max Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Use the Jimmy to pry the motherboard out of the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 385
