Ga door naar hoofdinhoud
ZTE Blade E Volume Button Replacement
Wat je nodig hebt
  1. ZTE Blade E Volume Button Replacement, Remove back panel from phone: stap 1, afbeelding 1 van 1
    • Using your finger nails or a spudger, remove the back panel from the phone.
  2. ZTE Blade E Volume Button Replacement, Remove battery and microSD card: stap 2, afbeelding 1 van 2 ZTE Blade E Volume Button Replacement, Remove battery and microSD card: stap 2, afbeelding 2 van 2
    • Using your fingernails or a spudger, remove the phones battery and microSD card.
  3. ZTE Blade E Volume Button Replacement, Remove back panel screws: stap 3, afbeelding 1 van 1
    • Remove the five 4mm Phillip's #00 screws, circled in red, from the back panel.
  4. ZTE Blade E Volume Button Replacement, Separate back panel from motherboard: stap 4, afbeelding 1 van 1
    • Separate the back panel from the motherboard.
  5. ZTE Blade E Volume Button Replacement, Remove volume button: stap 5, afbeelding 1 van 3 ZTE Blade E Volume Button Replacement, Remove volume button: stap 5, afbeelding 2 van 3 ZTE Blade E Volume Button Replacement, Remove volume button: stap 5, afbeelding 3 van 3
    • Using a pair of tweezers, remove the volume button by unlatching the two white bands holding it in place.
  6. ZTE Blade E Volume Button Replacement, Replace volume button: stap 6, afbeelding 1 van 2 ZTE Blade E Volume Button Replacement, Replace volume button: stap 6, afbeelding 2 van 2
    • Either replace the volume button with a new one, or reinsert the old one using a pair of tweezers. It should look like the pictures when inserted properly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sean Gardner
360 Reputatie
1 Handleiding geschreven
USF Tampa, Team 9-5, Leahy Fall 2014 Lid van USF Tampa, Team 9-5, Leahy Fall 2014
USFT-LEAHY-F14S9G5
3 Leden
10 handleidingen geschreven
2 opmerkingen
Ok my ZTE has gone insane it does whatever whenever it wants. Freezes, jumps around, locks, want download from play, home button don't work, plays music from unknown place. Went bought another just like it. A week and apparently it's contagious bc now other new phone is doing weird stuff volume button don't work sometimes freezes jumps and unfreeze, keyboard goes away and comes back
mirlace4 - Antwoord
cont..i posted bc iwas afraid it would eat mess. Serious here IDK what to do about to go outside and shoot both of them getting them out of there mystery
mirlace4 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,898
