Ga door naar hoofdinhoud
ZTE Axon 7 Battery Replacement
Wat je nodig hebt
  1. ZTE Axon 7 Battery Replacement, Back Case: stap 1, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Make sure the device is powered off.
    • Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
  2. ZTE Axon 7 Battery Replacement: stap 2, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement: stap 2, afbeelding 2 van 2
    • Heat the iOpener in the microwave for 15-30 seconds.
    • iOpener will be HOT! Use oven mitts if necessary.
    • Place the iOpener on top of the top and bottom speaker grills to loosen up the adhesive underneath.
  3. ZTE Axon 7 Battery Replacement: stap 3, afbeelding 1 van 3 ZTE Axon 7 Battery Replacement: stap 3, afbeelding 2 van 3 ZTE Axon 7 Battery Replacement: stap 3, afbeelding 3 van 3
    • Use a Jimmy to pry off the top and bottom speaker grills.
    • Remove the speaker grills gently so they don't crack or break off.
  4. ZTE Axon 7 Battery Replacement: stap 4, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the six 3 mm screws located under the speaker grills.
    • There may be remaining adhesive covering some screws. Take time to gently scrape away the adhesive using a spudger or opening tool.
  5. ZTE Axon 7 Battery Replacement: stap 5, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement: stap 5, afbeelding 2 van 2
    • Carefully wedge the Jimmy between the screen and aluminum back plate of the device.
    • Begin near the bottom right of the device and carefully work under the screen and slide the Jimmy up the edge of the device to remove the back case.
    • Use plastic picks to keep the display and back aluminum casing from closing as you pry along the perimeter of the phone with the Jimmy.
  6. ZTE Axon 7 Battery Replacement: stap 6, afbeelding 1 van 3 ZTE Axon 7 Battery Replacement: stap 6, afbeelding 2 van 3 ZTE Axon 7 Battery Replacement: stap 6, afbeelding 3 van 3
    • Separate the front and back of the phone, (like a book) to open and gain access to the internal components.
    • Careful to not damage the fingerprint sensor cable attached to the motherboard from the back casing.
    • Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
    • Be very careful to pry only under the edge of the connector, and not under the socket itself. If you pry under the socket, you will separate it from the circuit board, which requires specialized microsoldering skills and equipment to repair.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place. Don't press down on the middle of the connector until it's fully aligned and seated. If misaligned the connector can be permanently damaged.
  7. ZTE Axon 7 Battery Replacement: stap 7, afbeelding 1 van 1
    • The back is now completely removed.
  8. ZTE Axon 7 Battery Replacement, Battery: stap 8, afbeelding 1 van 3 ZTE Axon 7 Battery Replacement, Battery: stap 8, afbeelding 2 van 3 ZTE Axon 7 Battery Replacement, Battery: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    $3.99
    Koop
    • Use a Phillips #00 screwdriver to remove three 2.0 mm screw securing brackets on the top and bottom of the battery.
    • Use the angled tweezers and lift the bottom bracket up and off the phone.
    • Use the angled tweezers to slide the top bracket up and off the phone.
  9. ZTE Axon 7 Battery Replacement: stap 9, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement: stap 9, afbeelding 2 van 2
    • Disconnect both ends of the cable covering the battery by placing the tip of your opening tool or spudger under the edge of the connector and prying the connector straight up from its socket.
    • Remove the press fit cable.
    • Do not press down on the middle of wider connectors until they're fully seated—if misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
  10. ZTE Axon 7 Battery Replacement: stap 10, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement: stap 10, afbeelding 2 van 2
    • Place the tip of your opening tool or spudger under the edge of the battery connector, and pry the connector straight up from its socket to disconnect from the motherboard.
  11. ZTE Axon 7 Battery Replacement: stap 11, afbeelding 1 van 1
    • To remove the battery, use a spudger to carefully pry and slide along the edges of the battery in small increments to release the adhesive.
    • The adhesive under the battery is strong. Be sure to avoid puncturing and bending the battery.
    • Under the battery, on the left side, is a display cable. Be careful not to damage this cable if future intentions are to reuse the display for any purpose.
  12. ZTE Axon 7 Battery Replacement: stap 12, afbeelding 1 van 2 ZTE Axon 7 Battery Replacement: stap 12, afbeelding 2 van 2
    • Gently apply force and lift the battery out.
    • If you're having trouble lifting the battery, use the opening pick to slide further under the battery. This will help separate it from the adhesive.
    • Remove the battery, and replace with a new battery. Recycle old batteries as stated by your local regulations.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Laney Rodriguez
295 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 466
