Inleiding
This guide will show you how to replace the camera in case it breaks or no longer works.
Wat je nodig hebt
Remove the back cover of the phone to expose the phone's mid-frame.
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws along the perimeter of the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Use the tweezers to grip the back facing camera. Gently pull until the camera is completely removed from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
