Ga door naar hoofdinhoud
ZTE Avail 2 Camera Replacement
Wat je nodig hebt
  1. ZTE Avail 2 Camera Replacement, Battery: stap 1, afbeelding 1 van 3 ZTE Avail 2 Camera Replacement, Battery: stap 1, afbeelding 2 van 3 ZTE Avail 2 Camera Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: stap 2, afbeelding 1 van 2 ZTE Avail 2 Camera Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: stap 3, afbeelding 1 van 1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: stap 4, afbeelding 1 van 2 ZTE Avail 2 Camera Replacement: stap 4, afbeelding 2 van 2
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: stap 5, afbeelding 1 van 2 ZTE Avail 2 Camera Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: stap 6, afbeelding 1 van 1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: stap 7, afbeelding 1 van 2 ZTE Avail 2 Camera Replacement: stap 7, afbeelding 2 van 2
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: stap 8, afbeelding 1 van 3 ZTE Avail 2 Camera Replacement: stap 8, afbeelding 2 van 3 ZTE Avail 2 Camera Replacement: stap 8, afbeelding 3 van 3
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
Conclusie
5 andere personen hebben deze handleiding voltooid.
haugaustin
355 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 479
