Inleiding
In this guide, steps will be provided to remove and replace the left joystick on your ZD-N Plus Wireless Controller. The joystick might have to be replaced if the joystick is drifting, or if the joystick is not responding to your touch.
Wat je nodig hebt
Remove the electrical connector attaching each rumble motor to the controller.
Lift up on the circular section of the rumble to remove it from the controller.
Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
Pull up on the left joystick to remove it from the motherboard. The plastic piece will unclip easily.
Één andere persoon heeft deze handleiding voltooid.
