Ga door naar hoofdinhoud
ZD-N Plus Wireless Controller LB and RB Buttons Replacement
Wat je nodig hebt
  1. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 2, afbeelding 1 van 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 2, afbeelding 2 van 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 4, afbeelding 1 van 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 4, afbeelding 2 van 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 5, afbeelding 1 van 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Rumble Motor: stap 6, afbeelding 1 van 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Rumble Motor: stap 6, afbeelding 2 van 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
  7. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Motherboard: stap 7, afbeelding 1 van 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
  8. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: stap 8, afbeelding 1 van 1
    • Lift the motherboard out of the controller.
  9. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, LB and RB Buttons: stap 9, afbeelding 1 van 1
    • The LB/RB buttons can be easily pulled from the top of the controller.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 66
Altijd: 815
