Inleiding
Although professional grade drones are built to be robust, accidents and wear and tear may occur. Sometimes, it can be bad enough to cause the drone arm/motor to stop functioning, preventing operation of the drone. The drone arm suspends the propeller, allowing it to create lift for the drone unimpeded. Damage to this arm may prevent the propeller from working properly. This guide will show you how to replace a bad or broken drone arm on your Yuneec Typhoon H Plus drone. No special skills will be required to perform this replacement.
Wat je nodig hebt
Flip the drone over so the bottom is facing upwards.
Remove ten 9.5mm Hex 2 screws attached to the bottom shell.
Remove the small Phillips #000 screw that holds the arm clip in place.
Use iFixit's metal spudger to pry up on the clip to release it from the arm and pull it out with your fingers.
Één andere persoon heeft deze handleiding voltooid.
