Ga door naar hoofdinhoud
Yuneec Typhoon H Gimbal Bushing Reattachment
Wat je nodig hebt
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: stap 1, afbeelding 1 van 2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: stap 1, afbeelding 2 van 2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: stap 2, afbeelding 1 van 3 Yuneec Typhoon H Gimbal Bushing Reattachment: stap 2, afbeelding 2 van 3 Yuneec Typhoon H Gimbal Bushing Reattachment: stap 2, afbeelding 3 van 3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
Conclusie
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
Jake Breul
127 Reputatie
1 Handleiding geschreven
Cal Poly, Team S22-G3, Maness Spring 2018 Lid van Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Leden
5 handleidingen geschreven
3 opmerkingen
Camera not getting power after crash.
Don - Antwoord
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Antwoord
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,612
