Ga door naar hoofdinhoud
Yuneec Breeze 4K Motherboard Replacement
Wat je nodig hebt
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: stap 1, afbeelding 1 van 2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: stap 1, afbeelding 2 van 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: stap 2, afbeelding 1 van 3 Yuneec Breeze 4K Motherboard Replacement: stap 2, afbeelding 2 van 3 Yuneec Breeze 4K Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: stap 5, afbeelding 1 van 2 Yuneec Breeze 4K Motherboard Replacement: stap 5, afbeelding 2 van 2
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: stap 6, afbeelding 1 van 3 Yuneec Breeze 4K Motherboard Replacement: stap 6, afbeelding 2 van 3 Yuneec Breeze 4K Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: stap 7, afbeelding 1 van 3 Yuneec Breeze 4K Motherboard Replacement: stap 7, afbeelding 2 van 3 Yuneec Breeze 4K Motherboard Replacement: stap 7, afbeelding 3 van 3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: stap 9, afbeelding 1 van 2 Yuneec Breeze 4K Motherboard Replacement: stap 9, afbeelding 2 van 2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Ryanne Millis
318 Reputatie
1 Handleiding geschreven
UW Stout, Team S6-G5, Ogden Fall 2018 Lid van UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Leden
4 handleidingen geschreven
Één opmerking
Excellent step by step instructions.
paul_courville - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 1,932
