Ga door naar hoofdinhoud
Yujin Robot iCLEBO Arte Dust Bin Replacement
Wat je nodig hebt
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: stap 1, afbeelding 1 van 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: stap 2, afbeelding 1 van 2 Yujin Robot iCLEBO Arte Dust Bin Replacement: stap 2, afbeelding 2 van 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
Conclusie
To reassemble the dust bin, follow these instructions in reverse order.
Trent Treiber
204 Reputatie
2 handleidingen geschreven
USF Tampa, Team S2-G3, Nance Spring 2017 Lid van USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Leden
14 handleidingen geschreven
3 opmerkingen
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - Antwoord
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,084
