Ga door naar hoofdinhoud
Yamaha YPG-225 Keys Replacement
Wat je nodig hebt
  1. Yamaha YPG-225 Keys Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: stap 2, afbeelding 1 van 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: stap 3, afbeelding 1 van 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Keys Replacement, Faceplate: stap 4, afbeelding 1 van 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: stap 5, afbeelding 1 van 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: stap 6, afbeelding 1 van 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: stap 7, afbeelding 1 van 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: stap 8, afbeelding 1 van 2 Yamaha YPG-225 Keys Replacement: stap 8, afbeelding 2 van 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: stap 9, afbeelding 1 van 1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: stap 10, afbeelding 1 van 1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: stap 11, afbeelding 1 van 2 Yamaha YPG-225 Keys Replacement: stap 11, afbeelding 2 van 2
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: stap 12, afbeelding 1 van 1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Kevin Green
308 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-62, Propen Fall 2012 Lid van Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Leden
6 handleidingen geschreven
3 opmerkingen
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - Antwoord
Great article. Thank you so much.
Andreas Devig - Antwoord
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 21,162
