Ga door naar hoofdinhoud
Yamaha FG-425 Guitar String Replacement
Wat je nodig hebt
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: stap 1, afbeelding 1 van 3 Yamaha FG-425 Guitar String Replacement, Guitar String: stap 1, afbeelding 2 van 3 Yamaha FG-425 Guitar String Replacement, Guitar String: stap 1, afbeelding 3 van 3
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: stap 2, afbeelding 1 van 2 Yamaha FG-425 Guitar String Replacement: stap 2, afbeelding 2 van 2
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: stap 3, afbeelding 1 van 2 Yamaha FG-425 Guitar String Replacement: stap 3, afbeelding 2 van 2
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: stap 4, afbeelding 1 van 3 Yamaha FG-425 Guitar String Replacement: stap 4, afbeelding 2 van 3 Yamaha FG-425 Guitar String Replacement: stap 4, afbeelding 3 van 3
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: stap 5, afbeelding 1 van 2 Yamaha FG-425 Guitar String Replacement: stap 5, afbeelding 2 van 2
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: stap 6, afbeelding 1 van 1
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: stap 7, afbeelding 1 van 1
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Nicole Francheska Letigio
207 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 267
