Ga door naar hoofdinhoud
Yamaha Alto Saxophone Neck-piece Cork Replacement
Wat je nodig hebt
  1. Yamaha Alto Saxophone Neck-piece Cork Replacement, YAS-23 Yamaha Alto Saxophone Neck-piece Cork: stap 1, afbeelding 1 van 2 Yamaha Alto Saxophone Neck-piece Cork Replacement, YAS-23 Yamaha Alto Saxophone Neck-piece Cork: stap 1, afbeelding 2 van 2
    • The octave key is silver, while the rest of the neck-piece is gold.
    • Locate the screw on the side of the neck-piece, connecting the octave key to the neck-piece.
    • Use a small, 2.5 mm flat head screwdriver to remove the screw.
  2. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 2, afbeelding 1 van 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 2, afbeelding 2 van 2
    • Open a paperclip.
    • Push the screw out with the end of the paperclip.
  3. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 3, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 3, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 3, afbeelding 3 van 3
    • Slide the octave key down off the bottom of the neck-piece.
  4. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 4, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 4, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 4, afbeelding 3 van 3
    • Put on leather gloves.
    • Cut away from one's self.
    • Use the utility blade to scrape off the cork.
    • Start at the base of the cork on the neck-piece with the utility blade at a 10 to 20 degree angle.
    • In a controlled motion, drag the utility blade along the neck-piece, removing cork along the way.
    • Repeat until all of the cork is removed.
  5. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 5, afbeelding 1 van 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 5, afbeelding 2 van 2
    • Apply masking tape where there is no glue on the neck-piece to prevent damage to the finish.
  6. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 6, afbeelding 1 van 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 6, afbeelding 2 van 2
    • Remove glue and resin by rotating the neck-piece against the 220 grit sand paper.
    • Repeat until all glue is gone.
  7. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 7, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 7, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • New cork may not adhere correctly without completing this step.
    • With a damp microfiber cleaning cloth, wipe off any dust and glue particles.
  8. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 8, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 8, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 8, afbeelding 3 van 3
    • Do not remove adhesive covering on the Valentino neck cork.
    • Make sure the shorter base of the Valentino neck cork is flush with entrance.
    • Place the Valentino neck cork flush with the entrance of the neck-piece.
    • Mark a line where the Valentino neck cork meets the masking tape.
    • Cut along the line.
  9. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 9, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 9, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 9, afbeelding 3 van 3
    • Wrap Valentino neck cork around the neck-piece.
    • Make mark where the Valentino neck cork overlaps.
    • Make sure the shorter base of Valentino neck cork is flush with entrance to neck-piece.
    • If Valentino neck cork appears to be too small on one side, rotate 180 degrees.
  10. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 10, afbeelding 1 van 1
    • Cut the Valentino neck cork along the line made in the previous step.
  11. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 11, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 11, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 11, afbeelding 3 van 3
    • Remove the adhesive covering on the back of the Valentino neck cork.
    • Wrap the Valentino neck cork around the top of neck-piece.
    • Place the narrow end of the Valentino neck cork flush with the tip of the neck-piece.
  12. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 12, afbeelding 1 van 1
    • Remove the masking tape.
  13. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 13, afbeelding 1 van 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 13, afbeelding 2 van 2
    • Sand the seam of the Valentino neck cork until it is even with the rest of the Valentino neck cork.
  14. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 14, afbeelding 1 van 1
    • Apply a generous amount of cork grease on the whole Valentino neck cork.
  15. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 15, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 15, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 15, afbeelding 3 van 3
    • Place the octave key on the neck-piece.
  16. Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 16, afbeelding 1 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 16, afbeelding 2 van 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: stap 16, afbeelding 3 van 3
    • Re-insert the screw.
    • Tighten the screw with a small, 2.5 mm flat head screwdriver.
    • The replacement is complete.
    • When applying a mouthpiece to the neck-piece for the first time, it will be difficult and require force. This is normal.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
I’m usually here for computer guides, I couldn’t believe a sax guide was here! Was overjoyed! Can someone make a Alto Sax full pad replacement guide? I know it’s a big ask! But I have a YAS-23 and it needs all new pads, getting it serviced by a pro is between $700-$850!! But buying pads yourself is as low as $50 or on the high end $200. This seems like a tutorial the world needs to have! Thank you to anyone that even took the time to read this.
Cameron - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 1,765
