Ga door naar hoofdinhoud
Yamaha APX-6N Guitar Strings Replacement
Wat je nodig hebt
  1. Yamaha APX-6N Guitar Strings Replacement, Guitar strings: stap 1, afbeelding 1 van 1
    • Loosen the guitar strings by turning the tuning pegs counter clockwise.
  2. Yamaha APX-6N Guitar Strings Replacement: stap 2, afbeelding 1 van 1
    • To avoid injury, assure strings are loosened before cutting.
    • Once the strings are loose, cut them using the wire cutters.
    • After strings have been cut, remove them by pulling them out of the tuners and the bottom of the bridge.
  3. Yamaha APX-6N Guitar Strings Replacement: stap 3, afbeelding 1 van 2 Yamaha APX-6N Guitar Strings Replacement: stap 3, afbeelding 2 van 2
    • Insert the end of the string through the middle of the bridge until four inches comes through.
    • Wrap the short end of the string around the long end, making a loop.
    • Put the short end of the string through the loop around three to four times.
    • Pull both ends of the string until the knot is tight.
  4. Yamaha APX-6N Guitar Strings Replacement: stap 4, afbeelding 1 van 2 Yamaha APX-6N Guitar Strings Replacement: stap 4, afbeelding 2 van 2
    • Insert the end of the string into the hole on the correct tuning peg.
    • Pull the end over the tuning peg and loop under the string. Then push the end of the string under the loop.
    • Put the end of the string through the loop and pull both ends until the knot is tight.
  5. Yamaha APX-6N Guitar Strings Replacement: stap 5, afbeelding 1 van 2 Yamaha APX-6N Guitar Strings Replacement: stap 5, afbeelding 2 van 2
    • Repeat Step 4 for all other strings. Strings should be placed in the tuning pegs in clockwise order. Refer to string packaging for more details.
  6. Yamaha APX-6N Guitar Strings Replacement: stap 6, afbeelding 1 van 1
    • Turn the tuning pegs clockwise to tighten each string until the string makes a sound when plucked.
    • Do not overtighten the strings! Strings may snap and lead to injury.
  7. Yamaha APX-6N Guitar Strings Replacement: stap 7, afbeelding 1 van 1
    • After all strings have been replaced, tune the guitar to your desired tuning.
    • Check the headstock and the bridge for any loose string ends.
    • If necessary, use the wire cutters to snip off excess string.
    • The ends of the strings are very sharp.
Conclusie
You now have new strings for your guitar!
Benjamin
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 295
