Ga door naar hoofdinhoud
XtremeMac Luna Radio Jack Replacement
Wat je nodig hebt
  1. XtremeMac Luna Radio Jack Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 XtremeMac Luna Radio Jack Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 XtremeMac Luna Radio Jack Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Radio Jack Replacement: stap 2, afbeelding 1 van 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Radio Jack Replacement: stap 3, afbeelding 1 van 2 XtremeMac Luna Radio Jack Replacement: stap 3, afbeelding 2 van 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Radio Jack Replacement, Dock Circuit Board: stap 4, afbeelding 1 van 3 XtremeMac Luna Radio Jack Replacement, Dock Circuit Board: stap 4, afbeelding 2 van 3 XtremeMac Luna Radio Jack Replacement, Dock Circuit Board: stap 4, afbeelding 3 van 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna Radio Jack Replacement, Button Circuit Boards: stap 5, afbeelding 1 van 2 XtremeMac Luna Radio Jack Replacement, Button Circuit Boards: stap 5, afbeelding 2 van 2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna Radio Jack Replacement: stap 6, afbeelding 1 van 3 XtremeMac Luna Radio Jack Replacement: stap 6, afbeelding 2 van 3 XtremeMac Luna Radio Jack Replacement: stap 6, afbeelding 3 van 3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna Radio Jack Replacement: stap 7, afbeelding 1 van 2 XtremeMac Luna Radio Jack Replacement: stap 7, afbeelding 2 van 2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
  8. XtremeMac Luna Radio Jack Replacement, Radio Jack: stap 8, afbeelding 1 van 1
    • Remove the two 12mm Phillips head screws from the back of the device using a Phillips #1 screwdriver.
  9. XtremeMac Luna Radio Jack Replacement: stap 9, afbeelding 1 van 2 XtremeMac Luna Radio Jack Replacement: stap 9, afbeelding 2 van 2
    • Turn the Luna so that the display faces forward.
    • Pull the two white tabs to remove the cables from the front of the radio jack.
  10. XtremeMac Luna Radio Jack Replacement: stap 10, afbeelding 1 van 2 XtremeMac Luna Radio Jack Replacement: stap 10, afbeelding 2 van 2
    • Push the connections through the back casing and lift the radio jack up and out.
    • Reinserting the square AM switches can be tricky. Make sure they are aligned properly when you are reassembling the device.
  11. XtremeMac Luna Radio Jack Replacement: stap 11, afbeelding 1 van 2 XtremeMac Luna Radio Jack Replacement: stap 11, afbeelding 2 van 2
    • Desolder the positive connection (red) and the negative connection (black) on top of the radio jack to completely remove it.
Conclusie
David Ellison
18 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-47, Amido Spring 2013 Lid van Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 366
