Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The motherboard controls all of the Luna's operations. Use this guide to install it.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip the device over so that the batteries are closest to you. Remove the battery lid by pressing the battery cover's tab and pulling it away from the device. Push the battery against the spring and lift it out of the casing.
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you. Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. LCD iPhone-scherm fixkits
    De goedkope optie, ondersteund door onze levenslange garantie.
    Koop kits
    Bespaar op reparatiekosten, niet op kwaliteit.
    Koop kits
  5. Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case. Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case. Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  6. Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board. Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  7. Use a plastic opening tool to pry the black connections away from the top casing. Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside. Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
    I dont know why you would pull the rotary encoder apart when you can just push the silver button knob off the top of the radio by pushing it from below and then unscrew the rotary encoder from the lid afterwards. Much simpler and nothing gets damaged.
    Kristian Dahl Hansen - Antwoord
  8. Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs. The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
  9. Disconnect the white cables on the front of the radio jack. Disconnect the white cables on the front of the radio jack.
    • Disconnect the white cables on the front of the radio jack.
  10. Carefully remove the radio jack from the casing by pushing on the back connections. Gently remove the motherboard from the casing. Be careful with the display housing. Gently remove the motherboard from the casing. Be careful with the display housing.
    • Carefully remove the radio jack from the casing by pushing on the back connections.
    • Gently remove the motherboard from the casing. Be careful with the display housing.
Conclusie
David Ellison
18 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-47, Amido Spring 2013 Lid van Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Leden
8 handleidingen geschreven
Één commentaar
Where can i buy a motherboard to replace a broken one? What type of a motherboard should I buy? No idea at all.
Iris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 447
