Ga door naar hoofdinhoud
Xiaomi Redmi Note 3 Motherboard Replacement
Wat je nodig hebt
  1. Xiaomi Redmi Note 3 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the phone's top edge.
    • Press gently to eject the SIM tray
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Xiaomi Redmi Note 3 Motherboard Replacement: stap 2, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 2, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Insert a putty knife or opening tool into the seam between the phone's back cover and front cover.
    • Run the opening tool along the seam to loosen the back cover.
    • It may take quite a bit of prying and wiggling to remove the back cover.
    • Open the back cover slightly so that you can see the flex cable connected between both halves of the phone.
    • The flex cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  3. Xiaomi Redmi Note 3 Motherboard Replacement: stap 3, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 3, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Disconnect the flex cable using the flat end of a spudger or a pair of tweezers.
    • Remove the phone's back cover.
    • To reconnect the flex cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  4. Xiaomi Redmi Note 3 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five screws in the plastic covering at the bottom of the device.
  5. Xiaomi Redmi Note 3 Motherboard Replacement: stap 5, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 5, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Insert the flat end of a spudger under the plastic assembly cover at the bottom of the device.
    • Pry upwards with the spudger to lift the assembly cover.
    • Remove the assembly cover.
  6. Xiaomi Redmi Note 3 Motherboard Replacement: stap 6, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the battery flex cable from the lower assembly.
    • Use the flat end of a spudger to disconnect the ribbon cable on the left-hand side of the device.
  7. Xiaomi Redmi Note 3 Motherboard Replacement: stap 7, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 7, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Insert the flat end of a spudger under the assembly at the bottom of the device near the right-hand corner.
    • Pry upwards with the spudger to release the right-hand corner of the assembly.
    • Insert the flat end of a spudger under the assembly at the bottom of the device near the left-hand corner.
    • Pry upwards with the spudger to release the left-hand corner of the assembly.
    • Use your fingers to remove the assembly.
  8. Xiaomi Redmi Note 3 Motherboard Replacement: stap 8, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 8, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Peel back the barcode sticker so that it is disconnected from the battery.
    • Use your fingers to grasp the black battery adhesive tab and pull outwards firmly until the entire adhesive strip is released.
    • Repeat for the second battery adhesive strip.
  9. Xiaomi Redmi Note 3 Motherboard Replacement: stap 9, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Insert the flat end of a spudger underneath the battery.
    • Use your fingers to remove the battery.
  10. Xiaomi Redmi Note 3 Motherboard Replacement: stap 10, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Use a spudger to disconnect all marked ribbon cables.
  11. Xiaomi Redmi Note 3 Motherboard Replacement: stap 11, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the eight screws fastening the motherboard to the phone's interior.
  12. Xiaomi Redmi Note 3 Motherboard Replacement: stap 12, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use a pair of tweezers to remove the small metal piece from the top of the motherboard.
  13. Xiaomi Redmi Note 3 Motherboard Replacement: stap 13, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 13, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Slide an opening tool underneath the plastic assembly covering the upper portion of the motherboard.
    • Use your fingers or the opening tool to remove the plastic covering.
  14. Xiaomi Redmi Note 3 Motherboard Replacement: stap 14, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Slide an opening tool or the flat end of a spudger underneath the motherboard.
    • Pry upwards to loosen the motherboard from the phone's front cover.
  15. Xiaomi Redmi Note 3 Motherboard Replacement: stap 15, afbeelding 1 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 15, afbeelding 2 van 3 Xiaomi Redmi Note 3 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Gently lift the motherboard from its slot.
    • Use the flat end of a spudger to disconnect the cable from the bottom of the motherboard.
  16. Xiaomi Redmi Note 3 Motherboard Replacement: stap 16, afbeelding 1 van 2 Xiaomi Redmi Note 3 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Use your fingers to remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Arielle Sampson
17.068 Reputatie
1 Handleiding geschreven
1Gids Commentaar
mother board not starting and not working
Rinku Prajapati - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 52
Altijd: 1,496
