Ga door naar hoofdinhoud
Xiaomi Redmi 2 Front Speaker Replacement
Wat je nodig hebt
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: stap 1, afbeelding 1 van 2 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Front Speaker Replacement: stap 2, afbeelding 1 van 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Front Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Front Speaker Replacement: stap 4, afbeelding 1 van 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Front Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Front Speaker Replacement: stap 6, afbeelding 1 van 2 Xiaomi Redmi 2 Front Speaker Replacement: stap 6, afbeelding 2 van 2
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Front Speaker Replacement: stap 7, afbeelding 1 van 2 Xiaomi Redmi 2 Front Speaker Replacement: stap 7, afbeelding 2 van 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Front Speaker Replacement: stap 8, afbeelding 1 van 2 Xiaomi Redmi 2 Front Speaker Replacement: stap 8, afbeelding 2 van 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Front Speaker Replacement: stap 9, afbeelding 1 van 2 Xiaomi Redmi 2 Front Speaker Replacement: stap 9, afbeelding 2 van 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Front Speaker Replacement: stap 10, afbeelding 1 van 2 Xiaomi Redmi 2 Front Speaker Replacement: stap 10, afbeelding 2 van 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Front Speaker Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: stap 12, afbeelding 1 van 1
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Front Speaker Replacement: stap 13, afbeelding 1 van 1
    • Using your fingers, gently lift the front speaker from the screen assembly.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Alicia Brenner
3.539 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-3, Leahy Fall 2015 Lid van USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Leden
4 opmerkingen
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - Antwoord
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
brunofichos -
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - Antwoord
Rademi 2 front Speakers problem
Amol Surve - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 12
Altijd: 7,055
