Inleiding
This tutorial basically shows you how to correctly disassemble the Xiaomi Mi Bluetooth speaker. I had a problem with distorted sounds and some loose parts inside the speaker so I decided to open it up. At first I was looking for a disassembly tutorial for my device but I couldn't find any so I thought that I should make one myself.
Wat je nodig hebt
So that's the device, looks neat, nothing too special. Let's get right to it!
Now you have to remove this other front piece by prying it off with some kind of tool. I didn't have anything better and simply used some kind of hard plastic I found in my drawer. I suggest starting on the right side, since it's pretty much the only spot where you can start.
NOTE: It's attached with adhesive so you'll have to use a bit of force to get it off the main body. And also this piece is attached by a couple of very thin cables to the logic board so don't tear them apart.
Don't try to take off that marked connector. That's an unnecessary step.
Instead put the speaker with the front faced down and undo two screws to get off the smaller logic board with the usb-port, the on/off button and the small LED.
The bigger screw is there just for scale. You have to pay close attention when assembling the device not to use the wrong screws!
After you've removed that smaller logic board you'll be able to be more agile with your device.
Now just undo the four screws from both speakers. Both sides are pretty much the same. After removing both, you'll be able to remove the front frame.
At this point you are able to fix your loose battery with some duct tape or any other kind of adhesive you like!
When going back to the assembly and you don't know which speaker was on which side, you can see a small L and R on the logic board that'll help you!
And that is pretty much it! You can also see how I attached the battery lol. Before screwing the main logic board back to the back I'd suggest taping the Battery to the base from all sides to ensure that it is actually stable now.
To reassemble your device, follow these instructions in reverse order. And be careful please!
11 andere personen hebben deze handleiding voltooid.
15 opmerkingen
Partially. It got better but there was still some sort of distortion. I couldn't find the actual reason causing that distortion. And I somehow managed to break one of those little speakers so maybe I could open that one and see if I can find anything suspicious that causes the issue.
But for now, no solution for the distortion unfortunately :(
Emils -
Does everybody have distortion issues with this speaker?
