Ga door naar hoofdinhoud
Xiaomi Mi Pad Rear Camera Replacement
Wat je nodig hebt
  1. Xiaomi Mi Pad Rear Camera Replacement, Rear Case Assembly: stap 1, afbeelding 1 van 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Camera Replacement: stap 2, afbeelding 1 van 2 Xiaomi Mi Pad Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: stap 3, afbeelding 1 van 2 Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: stap 3, afbeelding 2 van 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Rear Camera Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to disconnect the rear-facing camera from the motherboard.
  6. Xiaomi Mi Pad Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the rear camera from the device.
Conclusie
Kiefer Sivitz
560 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-5, Blackwell Fall 2015 Lid van USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 706
