Ga door naar hoofdinhoud
Xiaomi Mi Pad Motherboard Replacement
Wat je nodig hebt
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: stap 1, afbeelding 1 van 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: stap 2, afbeelding 1 van 2 Xiaomi Mi Pad Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: stap 6, afbeelding 1 van 2 Xiaomi Mi Pad Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the motherboard from the device.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Kiefer Sivitz
560 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-5, Blackwell Fall 2015 Lid van USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Leden
13 handleidingen geschreven
4 opmerkingen
It's my email
amaank987321.msk@gmail.com
MSK DIGITAL MEDIA - Antwoord
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - Antwoord
I want mi pad mother board
Where I buy
Sunil - Antwoord
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 51
Altijd: 6,715
