Inleiding
Xiaomi's Mi 5 handset earns some points for modularity, but scores a middling 6 for overall repairability— mainly due to an unnecessarily fussy display replacement procedure.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
The screen has no visible fasteners, so we reluctantly use a suction cup and opening pick to start prying from the front.
The display finally separates from the midframe, but this design is a pain:
The LCD is held in place exclusively with glue, so reassembling the device means purchasing new adhesive designed for this unit.
Even though the screen is removed from the front, the LCD and digitizer connectors are not accessible without disassembling the back side.
The home button is trapped between the front panel assembly and the midframe, so replacing this (commonly failing) part will require removing and re-adhering the display.
The Xiaomi Mi 5 earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
The motherboard and battery can be replaced independently and easily.
Most components are modular and can be replaced independently.
All screws are standard Phillips screws, but removing them will void your warranty.
The display is difficult to replace, requiring complete disassembly and purchasing consumables.
The manufacturer does not provide user-accessible repair documentation.
54 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
Mi 5s replace battery guide pl
Thank you for the guide! Mine need battery replacement and this help me to replace it myself.
