Ga door naar hoofdinhoud
Xiaomi Mi 4 Rear Case/Midframe Replacement
Wat je nodig hebt
  1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: stap 1, afbeelding 1 van 3 Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: stap 1, afbeelding 2 van 3 Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: stap 1, afbeelding 3 van 3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Rear Case/Midframe Replacement: stap 2, afbeelding 1 van 3 Xiaomi Mi 4 Rear Case/Midframe Replacement: stap 2, afbeelding 2 van 3 Xiaomi Mi 4 Rear Case/Midframe Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Metal Spudger
    $2.99
    Koop
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Rear Case/Midframe Replacement: stap 3, afbeelding 1 van 3 Xiaomi Mi 4 Rear Case/Midframe Replacement: stap 3, afbeelding 2 van 3 Xiaomi Mi 4 Rear Case/Midframe Replacement: stap 3, afbeelding 3 van 3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Robert Cobaich
2.073 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-1, Blackwell Winter 2016 Lid van USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 4,272
