Ga door naar hoofdinhoud
Xiaomi Mi 4 Battery Replacement
Wat je nodig hebt
  1. Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: stap 1, afbeelding 1 van 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: stap 1, afbeelding 2 van 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: stap 1, afbeelding 3 van 3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Battery Replacement: stap 2, afbeelding 1 van 3 Xiaomi Mi 4 Battery Replacement: stap 2, afbeelding 2 van 3 Xiaomi Mi 4 Battery Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Metal Spudger
    $2.99
    Koop
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Battery Replacement: stap 3, afbeelding 1 van 3 Xiaomi Mi 4 Battery Replacement: stap 3, afbeelding 2 van 3 Xiaomi Mi 4 Battery Replacement: stap 3, afbeelding 3 van 3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
    I don't think it is necessary to remove the three 0.5mm screws. Note: the right-most orange circle should be placed instead of the red circle above the two larger orange circles - those are the 0.5mm screws which secures a small plate under the plastic cover which is in NOT physically (but electrically via two metal contacts) to the mainboard.
    Douglas Ling - Antwoord
    yes, I expirienced the same thing. the three stated screws fixing a module (the flashlight LED-plate) on the frame..
    mobbom - Antwoord
  4. Xiaomi Mi 4 Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Xiaomi Mi 4 Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Xiaomi Mi 4 Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
    my mi4 had an accu Model “BM32” .. I ordered BM33 first. but the dimensions of the accu are different, so one can install only the right one.
    mobbom - Antwoord
  5. Xiaomi Mi 4 Battery Replacement: stap 5, afbeelding 1 van 2 Xiaomi Mi 4 Battery Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
    Using a Pry tool damaged a bit the casing of the battery. I ended up pulling the battery's plastic sticker to remove it (adhesive holding the battery in place)
    James Burton - Antwoord
    Is it safe, can we fix the back cover perfectly?
    Hemen Bhatt - Antwoord
Conclusie
48 andere personen hebben deze handleiding voltooid.
William Pendeergraft
2.407 Reputatie
4 handleidingen geschreven
USF Tampa, Team 15-6, Blackwell Fall 2015 Lid van USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
2 Leden
10 handleidingen geschreven
24 opmerkingen
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Apawilo Zawk - Antwoord
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
Geoff Wacker -
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
adishsaggar123 - Antwoord
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
Hi..my xiaomi 4 cant be started.. after fully charged, it went blank n cant be restarted.. few days back, it was on n of for multiple time for several minutes...
Ezrat sam - Antwoord
same here do i need to change batteries?
overlord_345 -
Hi, I am trying to remove the battery but very firmly in the housing. Is it natural? Pull or use another way?
Seweryn Malczewski - Antwoord
it is normal just use some tool to remove it
adilmughal878 -
Hi,
Do you guys have a recommendation for a shop where I can buy a replacement battery?
Thank you for your answer!
Best regards
nils.heim - Antwoord
mi betrry can be replace if the betrry has been damage
fiza - Antwoord
Sir ..mine bettery has been damaged ...by getting swollen up...and mine device is mi4i...plss help me.!!!
Malav Patwa - Antwoord
I used this guide for a mi-4i model 2015015 and it was close enough but my phone had an addition 2 screws covered with orange stickers. this battery is a BM33 it did not have the large ribbon cable shown in step 4 just a small connector in the top middle of the battery but mostly this guide was very helpful and thank you.
Bobby Stephens - Antwoord
Hi, My Mi4i batter has bulged a little. Can any one explain why this happened & how to resolve!!
Biswajit Ghosh - Antwoord
That means that your battery is dangerously damaged has to be replaced ASAP. The battery could be a security hazard.
Chris Yang -
Hi.. My Mi4i battery has bulged a little. Is it make any problem & how to resolve!
Where can I order an mi4i bm33 battery? Im from Philippines.
macqz numlock - Antwoord
what does the number 2:36 on the upper left side of sceen mean
xoaomi redme 4x is a few month old!!battery is not shown decreasement,it stands still on “
in fact cellfone emptys wothin a day instead of 2 days
muspilli60 - Antwoord
I need a new battery..i accidently cut cable connectors.
How and where do I get a new battery in south Africa (pretoria)
pepito kashala - Antwoord
why dont you try online shopping apps? i am from Indonesia and i bought the parts from online shopping too well its indonesian Online shop so why not find and try african online shop or international online shop
Edric Sanjaya -
sir, my battery have been damaged by over charging.Now it only charges buh when removed from the socket.It drops back to zero.
christabel graboski - Antwoord
I have redmi 4 and redmi 4a I can exchange my battry to 4a it's possible
pramod joshi - Antwoord
My phone mi4 battery doesn't work properly It's drains very fast. The battery goes 0% but when I restart it become 46%. What should I do?
Gahlot Vines - Antwoord
Can we check mi phone battery genuinity if any one change the battery.
hitendrayadav10 - Antwoord
My phone got switched off after I put my phone for charging .it is not charging only sometimes my phone is heat but know I am keeping for charger my phone is cold I don't know what problem with my phone xiomi note 8.
munish babu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 92
Altijd: 147,229
