Ga door naar hoofdinhoud
Xiaomi Mi 3 Battery Replacement
Wat je nodig hebt
  1. Xiaomi Mi 3 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
  2. Xiaomi Mi 3 Battery Replacement: stap 2, afbeelding 1 van 2 Xiaomi Mi 3 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the two Phillips head screws located at the top of the phone on either side where the SIM card was ejected.
    • One screw is located under an orange sticker which would serve as your warranty for the camera were this practice not illegal as per the Magnuson–Moss Warranty Act of 1975.
  3. Xiaomi Mi 3 Battery Replacement: stap 3, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 3, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert a pry tool into the upper edge of the phone, where there is a small gap between screen and frame of the phone to begin separating the screen from the rest of the phone.
    • Be careful when using the pry tool as it can damage the phone's screen or other components.
  4. Xiaomi Mi 3 Battery Replacement: stap 4, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 4, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 4, afbeelding 3 van 3
    • Once the pry tool has been inserted into the phone, slide it around the perimeter of the phone while gently lifting until the screen panel and back panel of the phone separate.
  5. Xiaomi Mi 3 Battery Replacement: stap 5, afbeelding 1 van 2 Xiaomi Mi 3 Battery Replacement: stap 5, afbeelding 2 van 2
    • The back of the phone should now be separated from the screen.
  6. Xiaomi Mi 3 Battery Replacement: stap 6, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 6, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Place the front panel screen side down with the camera at the top.
    • Remove these six Phillips head screws located at the upper half of the phone.
    • This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
  7. Xiaomi Mi 3 Battery Replacement: stap 7, afbeelding 1 van 1
    • Next, remove these three screws located at the bottom of the back panel.
  8. Xiaomi Mi 3 Battery Replacement: stap 8, afbeelding 1 van 2 Xiaomi Mi 3 Battery Replacement: stap 8, afbeelding 2 van 2
    • Using tweezers, remove the rubber dust cover on the back panel of the phone.
  9. Xiaomi Mi 3 Battery Replacement: stap 9, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 9, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 9, afbeelding 3 van 3
    • Remove the plastic cover on the bottom of the back panel by inserting the pry tool at the edge and gently lifting.
  10. Xiaomi Mi 3 Battery Replacement: stap 10, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 10, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 10, afbeelding 3 van 3
    • Remove the upper plastic cover from the back panel by inserting the pry tool into the upper edge and gently lifting.
    • Some models have the NFC antenna at the back of the battery glued to the top cover. It is not possible to remove the top cover without removing the battery as well. For these models, check the touchscreen guide for instructions.
  11. Xiaomi Mi 3 Battery Replacement: stap 11, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 11, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 11, afbeelding 3 van 3
    • Using a spudger, remove the small ribbon cable that is connected to the battery.
  12. Xiaomi Mi 3 Battery Replacement: stap 12, afbeelding 1 van 3 Xiaomi Mi 3 Battery Replacement: stap 12, afbeelding 2 van 3 Xiaomi Mi 3 Battery Replacement: stap 12, afbeelding 3 van 3
    • Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
    • Some force may be required to remove the battery since it is adhered to the phone with two pieces of double sided tape.
  13. Xiaomi Mi 3 Battery Replacement: stap 13, afbeelding 1 van 1
    • The battery is now removed from the panel.
Conclusie
Prior to reassembly of the phone, inspect the battery for any leaking electrolyte. Leaking electrolytes is a sign of overheating, which can further damage the motherboard or cause the phone to catch fire. Clean any electrolyte from the phone using a cotton swab that is slightly damp with vinegar or lemon juice.
26 andere personen hebben deze handleiding voltooid.
Brian Cantler
797 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-5, Remmell Fall 2015 Lid van USF Tampa, Team 1-5, Remmell Fall 2015
USFT-REMMELL-F15S1G5
4 Leden
6 handleidingen geschreven
8 opmerkingen
Fr where do I gotta find a new battery after the removal of the old one???
Mohit Soni - Antwoord
Easily available on Ebay. I am about to replace mine 2nd time, work's fine though the discharge seems to be higher after almost a year of replacement. Phone's still good to go for another year or so hopefully. No serious lags :)
Kiran G -
thank you very much; changed my battery for the first time for 3 years.
Dave Adiastha - Antwoord
From where did you bought the battery for Mi 3
Durgesh Tanuku -
Hi I would like to know where can i find spare parts of Xiaomi MI3W. I have a MI3W whose internal USB Bus along with the USB port is damaged. Also touch is damaged, so need to purchase a display along with touch. So can anyone please guide me to a website where they sell spare parts of Xiaomi MI3W.
Sirish Kumar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 63
Altijd: 35,257
