Inleiding
This guide helps users replace the fuser in the Xerox C60 printer. Since the fuser is important for heating the toner and making it stay on the paper, it is a vital part of the machine. Replacing the fuser can help solve some issues with the printer, though not all. Some of these issues include consistent lines on the prints made. These lines will be in the same spot each time, and have consistent color to them. Another issue that may be fixed by replacing the fuser would be consistent paper jams. With this guide, users will be able to read what to do, as well as see photos of the replacement process being done, in an easy to read and understand guide. Before replacing the fuser, users should verify that the replacement part is indeed manufactured by Xerox, as one that is not may cause irreparable damage to the printer.
Wat je nodig hebt
Open the main printer door. This gives you access to the transfer case, which you will see in a moment.
The handle to the main door of the printer can be located just under the blue section, on the right hand side of the printer.
To close the printer, simply reverse these steps.
Één andere persoon heeft deze handleiding voltooid.
