Ga door naar hoofdinhoud
Xelio P900A-BK Battery Replacement
Wat je nodig hebt
  1. Xelio P900A-BK Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: stap 2, afbeelding 1 van 2 Xelio P900A-BK Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: stap 4, afbeelding 1 van 3 Xelio P900A-BK Battery Replacement: stap 4, afbeelding 2 van 3 Xelio P900A-BK Battery Replacement: stap 4, afbeelding 3 van 3
  5. Xelio P900A-BK Battery Replacement: stap 5, afbeelding 1 van 2 Xelio P900A-BK Battery Replacement: stap 5, afbeelding 2 van 2
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
Conclusie
Marcus Nelson
307 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-6, Cichon Spring 2015 Lid van UMass Dartmouth, Team 7-6, Cichon Spring 2015
UMASSD-CICHON-S15S7G6
3 Leden
8 handleidingen geschreven
Één opmerking
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 333
