Ga door naar hoofdinhoud
Xelio P1001A-BK Wi-Fi Antenna Replacement
Wat je nodig hebt
  1. Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: stap 1, afbeelding 1 van 2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Wi-Fi Antenna Replacement: stap 2, afbeelding 1 van 2 Xelio P1001A-BK Wi-Fi Antenna Replacement: stap 2, afbeelding 2 van 2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 3, afbeelding 1 van 2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 3, afbeelding 2 van 2
    • Desolder the connection on the motherboard.
    • Use a soldering vacuum to remove any excess solder.
  4. Xelio P1001A-BK Wi-Fi Antenna Replacement: stap 4, afbeelding 1 van 1
    • Use wire strippers to strip off at least 2 mm of wire insulation from each wire.
  5. Xelio P1001A-BK Wi-Fi Antenna Replacement: stap 5, afbeelding 1 van 1
    • Solder the outer wire braid shield to the ground point.
  6. Xelio P1001A-BK Wi-Fi Antenna Replacement: stap 6, afbeelding 1 van 1
    • Solder the center conductor to the antenna point.
Conclusie
Josh Saenz
316 Reputatie
3 handleidingen geschreven
Colorado Springs, Team 4-2, Panko Spring 2015 Lid van Colorado Springs, Team 4-2, Panko Spring 2015
UCCS-PANKO-S15S4G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 154
