Ga door naar hoofdinhoud
Xbox One Wireless Controller Thumbstick Replacement
Wat je nodig hebt
  1. Xbox One Wireless Controller Thumbstick Replacement, Battery Pack: stap 1, afbeelding 1 van 1
    • Remove the battery pack cover.
    • Remove batteries.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox One Wireless Controller Thumbstick Replacement, Side Handles: stap 2, afbeelding 1 van 2 Xbox One Wireless Controller Thumbstick Replacement, Side Handles: stap 2, afbeelding 2 van 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox One Wireless Controller Thumbstick Replacement, Screws: stap 3, afbeelding 1 van 2 Xbox One Wireless Controller Thumbstick Replacement, Screws: stap 3, afbeelding 2 van 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox One Wireless Controller Thumbstick Replacement, Backplate: stap 4, afbeelding 1 van 1
    • Remove the backplate.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox One Wireless Controller Thumbstick Replacement, Faceplate: stap 5, afbeelding 1 van 1
    • Remove the faceplate.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: stap 6, afbeelding 1 van 2 Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: stap 6, afbeelding 2 van 2
    • Remove thumbsticks by pulling them up off their poles.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
205 andere personen hebben deze handleiding voltooid.
Garrett George
6.482 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-15, Maness Winter 2015 Lid van Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Leden
54 handleidingen geschreven
32Gids Commentaar
Is there any advice for a controller that has had this repair, but continues to drift? I have done this repair successfully many times, and now i have a controller that (with 2 different replacement parts) continues to drift.
Is there a reset or config I can do?
Jim - Antwoord Deel
Drift issues are a different problem you would need to solder a new joystick box to fix that this is for loose or damaged thumb sticks
myhero667 - Antwoord Deel
I used a cotton ball on my Xbox one Elite to fix drifting issues.
ajcroyle - Antwoord Deel
Does anyone know the correct SKU for the joystick box for the Model 1537 in particular? And any link to purchase it. Thanks
ZuYao - Antwoord Deel
Can i apply 2 thumbsticks off the xbox 360 controller when i removed them?
Merlijn Fransen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 30
Afgelopen 7 dagen: 184
Afgelopen 30 dagen: 881
Altijd: 404,168
