Ga door naar hoofdinhoud
Xbox One Wireless Controller Model 1708 Top Motherboard Replacement
Wat je nodig hebt
  1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: stap 1, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: stap 1, afbeelding 2 van 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 2, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: stap 4, afbeelding 1 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: stap 4, afbeelding 2 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: stap 4, afbeelding 3 van 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 5, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
  7. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Directional Pad: stap 7, afbeelding 1 van 1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
  8. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Joystick Caps: stap 8, afbeelding 1 van 1
    • Pull the joysticks off of the controller.
  9. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Top Motherboard: stap 9, afbeelding 1 van 1
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
  10. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: stap 10, afbeelding 1 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: stap 10, afbeelding 2 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: stap 10, afbeelding 3 van 3
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
Conclusie
20 andere personen hebben deze handleiding voltooid.
Lien (Ally) Quan
915 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G3, Forte Fall 2017 Lid van Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Leden
32 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 335
Altijd: 24,357
