Ga door naar hoofdinhoud
Xbox One Wireless Controller Model 1708 Directional Pad Replacement
Wat je nodig hebt
  1. Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Cover Plate: stap 1, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Cover Plate: stap 1, afbeelding 2 van 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: stap 2, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Directional Pad Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: stap 3, afbeelding 1 van 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Tape Shock Motors in place: stap 4, afbeelding 1 van 3 Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Tape Shock Motors in place: stap 4, afbeelding 2 van 3 Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Tape Shock Motors in place: stap 4, afbeelding 3 van 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: stap 5, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Directional Pad Replacement: stap 5, afbeelding 2 van 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Directional Pad Replacement: stap 6, afbeelding 1 van 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
  7. Xbox One Wireless Controller Model 1708 Directional Pad Replacement, Directional Pad: stap 7, afbeelding 1 van 1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
Conclusie
19 andere personen hebben deze handleiding voltooid.
Dylan Gross
4.692 Reputatie
4 handleidingen geschreven
Cal Poly, Team S18-G3, Forte Fall 2017 Lid van Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Leden
32 handleidingen geschreven
7 opmerkingen
Will one of the D-pads from the Xbox One controller model 1698 fit and work with the Xbox One-S controller model 1708. I have been looking all over the net for a replacement D-pad and other buttons like the RB, LB Bumper setup and I have had absolutely no luck finding replacement D-pads or other buttons specifically designed for the Xbox One-S controller. I would greatly appreciate your help.
Walter “Biggdubbya” Kloster - Antwoord
My D-pad was not working properly so I dropped drops of alcohol and other cleaners to fix the issue since the screws inside my controller were stripped and I was unable to open it and at the beginning it worked but then It started failing again so I did it again and this time the left direction is dead. I sent it to be repaired and they told it couldn't be salvaged yet they repaired the thumbsticks just to force me to pay them.
Diego Jose - Antwoord
The D-pad on our controller sticks. I disassembled the device and discovered one of the small metal pieces that are supposed to spring back after the button is pressed has been deformed. I will need new ones, but I don’t know what to call the part or where to get it, but I’m sure it’s pennies? Any suggestions? I’d add a photo if I could here.
Joseph Greer - Antwoord
Search for “Xbox One Controller Replacement D-Pad Button Metal Dome Conductive Film Sticker” on Amazon, NewEgg or Ebay. Should cost 5-10 bucks. Cheaper if you get it shipped from China, but takes forever.
Sudil Mahendra -
I too have disassembled a controller to discover that this is the cause of the D-Pad not functioning on one side. I am however unsure of how to remove the damaged part as the guide only covers removing the D-Pad itself.
Mark Smith -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 212
Altijd: 12,159
