Ga door naar hoofdinhoud
Xbox One Wireless Controller Model 1537 Disassembly
Wat je nodig hebt
  1. Xbox One Wireless Controller Model 1537 Disassembly, Controller: stap 1, afbeelding 1 van 1
    • Remove the battery cover and batteries.
  2. Xbox One Wireless Controller Model 1537 Disassembly: stap 2, afbeelding 1 van 2 Xbox One Wireless Controller Model 1537 Disassembly: stap 2, afbeelding 2 van 2
    • Remove the side handles by wedging a spudger in between the front and side panels.
    • To pry the side panel off move the spudger back and forth do this along the entire seam to remove the side panel.
  3. Xbox One Wireless Controller Model 1537 Disassembly: stap 3, afbeelding 1 van 1
    • Using a T8 security torxs screwdriver remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label you can either remove the label or poke a hole through it.
  4. Xbox One Wireless Controller Model 1537 Disassembly: stap 4, afbeelding 1 van 1
    • After removing the screws the front panel should come off easily .
  5. Xbox One Wireless Controller Model 1537 Disassembly: stap 5, afbeelding 1 van 1
    • Remove the back plate.
Conclusie
shiv
187 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 24
Altijd: 2,693
