Ga door naar hoofdinhoud
Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement
Wat je nodig hebt
  1. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement, Bumper: stap 1, afbeelding 1 van 1
    • Remove the battery cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 2, afbeelding 1 van 3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 2, afbeelding 2 van 3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 2, afbeelding 3 van 3
    • Grip the controller firmly to remove the side handle cover.
    • Use a flathead screwdriver or a spudger to wedge between the seams of the front to the side handle of the controller.
    • Move the flathead screwdriver all the way around the side plates seam and push the plate forward.
  3. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 3, afbeelding 1 van 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 3, afbeelding 2 van 2
    • Use a screwdriver and punch a hole directly in the center label. There you will find a hidden screw.
    • Remove the five 10mm screws located on the back of the controller using a T8 screwdriver.
  4. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 4, afbeelding 1 van 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 4, afbeelding 2 van 2
    • Remove the backplate.
  5. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 5, afbeelding 1 van 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 5, afbeelding 2 van 2
    • Remove the faceplate.
  6. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 6, afbeelding 1 van 3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 6, afbeelding 2 van 3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 6, afbeelding 3 van 3
    • Remove the cover piece surrounding the Xbox button off of its pegs.
    • Firmly hold controller and push cover piece up from the pegs.
    • Press the Xbox button down to assist in the unclipping of the piece.
  7. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 7, afbeelding 1 van 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 7, afbeelding 2 van 2
    • Remove the broken bumper by unclipping it from its pegs.
    • Hold the controller firmly and push the bumper piece up from its pegs to unclip.
  8. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 8, afbeelding 1 van 3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 8, afbeelding 2 van 3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: stap 8, afbeelding 3 van 3
    • Align the replacement bumper onto the pegs, push gently and click into place.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Cristyne Ramirez
541 Reputatie
1 Handleiding geschreven
2 opmerkingen
On my controller the screws were T8 security type, so you'll need bits with a hole in the middle
Sean H - Antwoord
Is there a way to do this without removing all of the front and grip.
Alan Marantos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 298
Afgelopen 30 dagen: 1,267
Altijd: 34,406
