Ga door naar hoofdinhoud
Xbox One Wi-Fi Board Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Xbox One Wi-Fi Board Replacement, Side Vent: stap 1, afbeelding 1 van 3 Xbox One Wi-Fi Board Replacement, Side Vent: stap 1, afbeelding 2 van 3 Xbox One Wi-Fi Board Replacement, Side Vent: stap 1, afbeelding 3 van 3
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
  2. Xbox One Wi-Fi Board Replacement, Wi-Fi Board: stap 2, afbeelding 1 van 2 Xbox One Wi-Fi Board Replacement, Wi-Fi Board: stap 2, afbeelding 2 van 2
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
  3. Xbox One Wi-Fi Board Replacement: stap 3, afbeelding 1 van 3 Xbox One Wi-Fi Board Replacement: stap 3, afbeelding 2 van 3 Xbox One Wi-Fi Board Replacement: stap 3, afbeelding 3 van 3
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
  4. Xbox One Wi-Fi Board Replacement: stap 4, afbeelding 1 van 2 Xbox One Wi-Fi Board Replacement: stap 4, afbeelding 2 van 2
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
  5. Xbox One Wi-Fi Board Replacement: stap 5, afbeelding 1 van 3 Xbox One Wi-Fi Board Replacement: stap 5, afbeelding 2 van 3 Xbox One Wi-Fi Board Replacement: stap 5, afbeelding 3 van 3
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
  6. Xbox One Wi-Fi Board Replacement: stap 6, afbeelding 1 van 2 Xbox One Wi-Fi Board Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
  7. Xbox One Wi-Fi Board Replacement: stap 7, afbeelding 1 van 2 Xbox One Wi-Fi Board Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
  8. Xbox One Wi-Fi Board Replacement: stap 8, afbeelding 1 van 1
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Gwendolyn Church
1.500 Reputatie
6 handleidingen geschreven
Cal Poly, Team 6-22, Maness Winter 2014 Lid van Cal Poly, Team 6-22, Maness Winter 2014
CPSU-MANESS-W14S6G22
4 Leden
11 handleidingen geschreven
Één opmerking
My wireless work ,But my WIFI is not working .It say my network passwork don't work . I have put all my password and nothing work. What else can I do to fix it . Or Can I get someone else to come can fix it for me.
rosahoneybee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 7,920
