Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Gently pull up on the speaker cable connector to disconnect it from the front panel board.
Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
Lift the Wi-Fi board straight up from its socket in the upper metal case.
Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
Disconnect the Wi-Fi board interconnect cable from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
