Inleiding
So you've confirmed your Xbox One S cannot connect to any Wi-Fi sources, but other devices can. Follow these steps to replace the Wi-Fi card.
Wat je nodig hebt
Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
22 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
T8 Torx Bit Screwdriver
15 mm long hense the name
So I have replaced the Wi-Fi card from the Wi-Fi I bought from ifixit and my console cannot still connect to the Wi-Fi but my other devices can any help?
