Ga door naar hoofdinhoud
Xbox One S Interior Case Top Panel Replacement
Wat je nodig hebt
  1. Xbox One S Interior Case Top Panel Replacement, Case: stap 1, afbeelding 1 van 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Interior Case Top Panel Replacement: stap 2, afbeelding 1 van 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Interior Case Top Panel Replacement: stap 3, afbeelding 1 van 1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Interior Case Top Panel Replacement: stap 4, afbeelding 1 van 2 Xbox One S Interior Case Top Panel Replacement: stap 4, afbeelding 2 van 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Interior Case Top Panel Replacement: stap 5, afbeelding 1 van 2 Xbox One S Interior Case Top Panel Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
  6. Xbox One S Interior Case Top Panel Replacement, Interior Case Top Panel: stap 6, afbeelding 1 van 1
    • Flip the interior case so it is fan side upward.
  7. Xbox One S Interior Case Top Panel Replacement: stap 7, afbeelding 1 van 1
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Andrew
5.223 Reputatie
3 handleidingen geschreven
Cal Poly, Team S22-G3, Livingston Spring 2017 Lid van Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Leden
56 handleidingen geschreven
Één opmerking
Pourquoi ma X boxe One s'allume plus
Karim hamadi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 142
Altijd: 5,974
