Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Xbox One S Case Replacement
Wat je nodig hebt
  1. Xbox One S Case Replacement, Case: stap 1, afbeelding 1 van 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Case Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
  3. Xbox One S Case Replacement: stap 3, afbeelding 1 van 1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Case Replacement: stap 4, afbeelding 1 van 2 Xbox One S Case Replacement: stap 4, afbeelding 2 van 2
    • Find all of the green screws on the metal case labeled F1 through F6.
    • Take the T10 Torx screwdriver and remove the six 50 mm long screws.
  5. Xbox One S Case Replacement: stap 5, afbeelding 1 van 3 Xbox One S Case Replacement: stap 5, afbeelding 2 van 3 Xbox One S Case Replacement: stap 5, afbeelding 3 van 3
    • Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
    • This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing.
    • Look at the image in Step 7 for clarification on how the exterior case disassembles.
  6. Xbox One S Case Replacement: stap 6, afbeelding 1 van 2 Xbox One S Case Replacement: stap 6, afbeelding 2 van 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
Conclusie
36 andere personen hebben deze handleiding voltooid.
Christopher Chen
621 Reputatie
2 handleidingen geschreven
Cal Poly, Team S22-G3, Livingston Spring 2017 Lid van Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Leden
56 handleidingen geschreven
5 opmerkingen
I struggled with the retention tabs the first time I opened the Xbox S. I dabbed a little Armor All on a Qtip and coated both sides of tabs with a little. Popped right open the second time, wiped Armor All on the fan blades as well to minimize dust collection.
Mike DePedro - Antwoord
Hi!
Great review of the process! I have a question, having stripped down an rebuilt an XBox One S to extract a 500 yuan note and two peties my 7 year old inserted in the CD/DVD slop, as well as a DOA DVD drive the power switch is not working. It works if I short the contact but there appears to be a square hole in the back of the power switch (the x box logo)
Should there be a conducting contact in the back of the switch and if so, is it simply a square lump of steel or is it tapered? Would like the dimensions please.
Many thanks for taking time to reply!
Dr B
Dr John C Bullas
Southampton UK
john.bullas - Antwoord
Hi can u fit a core i5 apple gen in Xbox one s case
Aayan Beast - Antwoord
Excuse me but is there an everyday item that I can use to open the bottom of my Xbox one s with?
Brody Luce - Antwoord
CAUTION: Sheared off power and pairing switches when attempting to affix to panel.
Mark - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 136
Afgelopen 30 dagen: 769
Altijd: 63,265
