Inleiding
This step covers how to remove the plastic case of the Xbox One S All Digital Edition (Model 1681). This is a necessary step to repair anything inside the Xbox. Be aware, this step may require some force if the plastic case has not been removed before, and there is a chance some parts of it break. Popping out the tabs inside the black cover may take some time. Disconnect all cables prior to disassembly.
Wat je nodig hebt
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Één andere persoon heeft deze handleiding voltooid.
