Ga door naar hoofdinhoud
Xbox One S All Digital Edition Plastic Enclosure Replacement
Wat je nodig hebt
  1. Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: stap 1, afbeelding 1 van 3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: stap 1, afbeelding 2 van 3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: stap 1, afbeelding 3 van 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Plastic Enclosure Replacement: stap 2, afbeelding 1 van 2 Xbox One S All Digital Edition Plastic Enclosure Replacement: stap 2, afbeelding 2 van 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Plastic Enclosure Replacement: stap 3, afbeelding 1 van 2 Xbox One S All Digital Edition Plastic Enclosure Replacement: stap 3, afbeelding 2 van 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Plastic Enclosure Replacement: stap 4, afbeelding 1 van 1
    • Flip the metal enclosure so that the fan cover is on top.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jules Hajjar
1.549 Reputatie
8 handleidingen geschreven
Cal Poly, Team S12-G6, Regan Fall 2019 Lid van Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 54
Altijd: 2,365
