Inleiding
This replacement guide provides a step by step process on replacing the Hard Drive of the Xbox One S All Digital Edition (Model 1681). The Hard Drive is responsible for storing games or any downloadable content. Symptoms of a broken Hard Drive are if a user is unable to download or access downloaded games or content. Disconnect all cables prior to disassembly.
Wat je nodig hebt
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
Remove the two 10mm screws, labeled C3 and C4, attaching the plastic hard drive case to the metal chassis with the Torx T10 Security screwdriver.
13 andere personen hebben deze handleiding voltooid.
