Ga door naar hoofdinhoud
Xbox One S All Digital Edition Bottom Metal Shield Replacement
Wat je nodig hebt
  1. Xbox One S All Digital Edition Bottom Metal Shield Replacement, Plastic Enclosure: stap 1, afbeelding 1 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Plastic Enclosure: stap 1, afbeelding 2 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Plastic Enclosure: stap 1, afbeelding 3 van 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 2, afbeelding 1 van 2 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 2, afbeelding 2 van 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 3, afbeelding 1 van 2 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 3, afbeelding 2 van 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 4, afbeelding 1 van 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Bottom Metal Shield Replacement, Top Metal Shield: stap 5, afbeelding 1 van 2 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Top Metal Shield: stap 5, afbeelding 2 van 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 6, afbeelding 1 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 6, afbeelding 2 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 6, afbeelding 3 van 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Bottom Metal Shield Replacement, Bottom Metal Shield: stap 7, afbeelding 1 van 2 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Bottom Metal Shield: stap 7, afbeelding 2 van 2
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  8. Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 8, afbeelding 1 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 8, afbeelding 2 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 8, afbeelding 3 van 3
    • Remove the two plastic pieces from the motherboard.
  9. Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 9, afbeelding 1 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 9, afbeelding 2 van 3 Xbox One S All Digital Edition Bottom Metal Shield Replacement: stap 9, afbeelding 3 van 3
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jules Hajjar
1.573 Reputatie
8 handleidingen geschreven
Cal Poly, Team S12-G6, Regan Fall 2019 Lid van Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 96
Altijd: 2,812
