Inleiding
Infrared blasters emulate an IR signal. This is used to remote-control other equipment in the vicinity of the Kinect. The IR blasters are mounted on the heat sink inside the Kinect.
Wat je nodig hebt
Remove the sticker on the underside of the device.
Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
Lift the internal assembly with the spudger.
Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
Using a T5 torx driver, remove the four 1.9x10 mm screws on the corners of the blasters.
Remove the two 1.9x5.1 mm T5 screws on the right-hand side of the board.
