Ga door naar hoofdinhoud
Xbox One Heat Sink Assembly Replacement
Wat je nodig hebt
  1. Xbox One Heat Sink Assembly Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Heat Sink Assembly Replacement: stap 2, afbeelding 1 van 3 Xbox One Heat Sink Assembly Replacement: stap 2, afbeelding 2 van 3 Xbox One Heat Sink Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Heat Sink Assembly Replacement: stap 3, afbeelding 1 van 3 Xbox One Heat Sink Assembly Replacement: stap 3, afbeelding 2 van 3 Xbox One Heat Sink Assembly Replacement: stap 3, afbeelding 3 van 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  4. Xbox One Heat Sink Assembly Replacement, Heat Sink Assembly: stap 4, afbeelding 1 van 2 Xbox One Heat Sink Assembly Replacement, Heat Sink Assembly: stap 4, afbeelding 2 van 2
    • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
    • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
  5. Xbox One Heat Sink Assembly Replacement: stap 5, afbeelding 1 van 3 Xbox One Heat Sink Assembly Replacement: stap 5, afbeelding 2 van 3 Xbox One Heat Sink Assembly Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
  6. Xbox One Heat Sink Assembly Replacement: stap 6, afbeelding 1 van 3 Xbox One Heat Sink Assembly Replacement: stap 6, afbeelding 2 van 3 Xbox One Heat Sink Assembly Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Detach the ribbon cable leading to the microphone with the tweezers.
    • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
    • Remove the stand.
  7. Xbox One Heat Sink Assembly Replacement: stap 7, afbeelding 1 van 3 Xbox One Heat Sink Assembly Replacement: stap 7, afbeelding 2 van 3 Xbox One Heat Sink Assembly Replacement: stap 7, afbeelding 3 van 3
    • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
    • Peel away the plastic film from the motherboard using the spudger.
    • Detach the ribbon cable leading to the color camera using the spudger.
  8. Xbox One Heat Sink Assembly Replacement: stap 8, afbeelding 1 van 3 Xbox One Heat Sink Assembly Replacement: stap 8, afbeelding 2 van 3 Xbox One Heat Sink Assembly Replacement: stap 8, afbeelding 3 van 3
    • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Malak Anshassi
329 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Hickman Fall 2014 Lid van USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 1,789
