Ga door naar hoofdinhoud
Xbox One Elite Controller Series 2 Left Joystick Replacement
Wat je nodig hebt
Video-instructies
Conclusie
7 andere personen hebben deze handleiding voltooid.
@HectorNavarroMX
4.405 Reputatie
26 handleidingen geschreven
13Gids Commentaar
Does this work for the series 1 elite controller also?
Nicola - Antwoord
Can we please get some insight to what the silver tape that is put over certain leads?
- What is the silver tape?
- What is the silver tape used for?
- Which leads are the silver tape covering?
- What happens if silver tape is not used?
Noah Adams - Antwoord
It is called Kapton Tape. It is used to protect components from heat during the rework process. If you don't use it, there is a chance of damaging the components. Even though the damage may not be seen by the naked eye. Hope this helps!
Ken Stopczynski -
It is aluminum tape not kapton tape. It is covering a surface mount component mounted within the area of the pins you have to desolder to remove the analog stick. He is covering it up to protect it from the heat and also to keep it from desoldering and moving while replacing the analog stick.
Damon Rowan -
ma per caso accetti spedizioni, perché anche a me mi si è rotto così
Gabriel Pisciotta - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 43
Afgelopen 7 dagen: 271
Afgelopen 30 dagen: 1,107
Altijd: 55,633
