Wat je nodig hebt
You can pop the connector up to remove the ribbon easily.
Ribbon Cable
Desolder the 4 wires on each side, these control the vibrations and the RT LT.
Pull up from the "top" side of the controller on the daughterboard.
Now you can remove the buttons themselves.
45 andere personen hebben deze handleiding voltooid.
14Gids Commentaar
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
