Ga door naar hoofdinhoud
Xbox One Elite Controller (Model 1698) Daughterboard Replacement
Wat je nodig hebt
  1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: stap 1, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: stap 1, afbeelding 2 van 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Removing the back panel screws: stap 2, afbeelding 1 van 1
    • Remove the 5 Torx Security Bit (TR9) screws
  3. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: stap 3, afbeelding 1 van 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: stap 3, afbeelding 2 van 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: stap 3, afbeelding 3 van 3
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: stap 4, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: stap 4, afbeelding 2 van 2
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Screws on controller motherboard: stap 5, afbeelding 1 van 1
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: stap 6, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: stap 6, afbeelding 2 van 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
  7. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: stap 7, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: stap 7, afbeelding 2 van 2
    • Pull up from the "top" side of the controller on the sister board.
  8. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: stap 8, afbeelding 1 van 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: stap 8, afbeelding 2 van 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: stap 8, afbeelding 3 van 3
    • Be Careful to not lose the sync button
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part
  9. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: stap 9, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: stap 9, afbeelding 2 van 2
    • Unscrew the 6 Torx (T6) screws
Conclusie
EasyAsABC123
2.407 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 80
Altijd: 8,300
