Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Xbox 360 Wireless Controller te repareren, gebruik onze reparatiehandleidingen.
  1. Xbox 360 Wireless Controller, Introduction: stap 1, afbeelding 1 van 3 Xbox 360 Wireless Controller, Introduction: stap 1, afbeelding 2 van 3 Xbox 360 Wireless Controller, Introduction: stap 1, afbeelding 3 van 3
    • This is the Xbox 360 wireless controller we are going to work with
  2. Xbox 360 Wireless Controller, Took out all the screws and torn apart: stap 2, afbeelding 1 van 3 Xbox 360 Wireless Controller, Took out all the screws and torn apart: stap 2, afbeelding 2 van 3 Xbox 360 Wireless Controller, Took out all the screws and torn apart: stap 2, afbeelding 3 van 3
    • I unscrewed the screws with a special screwdriver called Torx 8 T8 screwdriver.
  3. Xbox 360 Wireless Controller, I found a thing that’s looks like a motor: stap 3, afbeelding 1 van 3 Xbox 360 Wireless Controller, I found a thing that’s looks like a motor: stap 3, afbeelding 2 van 3 Xbox 360 Wireless Controller, I found a thing that’s looks like a motor: stap 3, afbeelding 3 van 3
    • I was looking at the different parts and I found two vibration rumble motors that make the controller vibrate. For example if you play call of duty and you shoot a gun the controller will vibrate.
  4. Xbox 360 Wireless Controller, I look at the backside of the controller: stap 4, afbeelding 1 van 3 Xbox 360 Wireless Controller, I look at the backside of the controller: stap 4, afbeelding 2 van 3 Xbox 360 Wireless Controller, I look at the backside of the controller: stap 4, afbeelding 3 van 3
    • I figured out how to open the other side found three things. I didn't know what they were and I found out they were the triggers for the controller. I also found out how the batteries connect to the controller. Finally, I found out that they where motors connect and I found out. I I also notice the processor chip was the same as a calculator.
Jose fierros
119 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 142
Altijd: 2,354
